Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Street triple rs not starting  (Read 1604 times)
Offline enakki
  • Gender: Male
  • Country: Slovakia
Re: Street triple rs not starting
« Reply #10 on: August 12, 2017, 03:54:14 PM »
*Originally Posted by shaun [+]
Are these bikes that have problems starting on a optimate charger?.
not mine. I dont think it is battery-related problem. Mine was staying in quite warm garage and just for two days. I'll see how it will behave in upcomming days but will have to visit dealer regarding the frozen clock. It seems the time is completely frozen even time trip is still on zero after the reset.
  • Gender: Male
« Reply #11 on: August 12, 2017, 04:02:09 PM »
I dare bet your battery is low on power, can you use a multi meter to check the volts across the battery terminals? With the 675 there's been problems with clocks going mad and in most cases it was a flat battery,I would invest in a optimate.
Offline jonny1978
  • Gender: Male
« Reply #12 on: August 12, 2017, 04:47:43 PM »
Done 50 miles on my bike the night before and pulled it out in the morning and it wouldn't start. Don't think its a battery problem
Cranked very strong and no hint of low power as I cranked it 10 times for around 10 sec a time and it never slowed the crank.
  • Gender: Male
« Reply #13 on: August 12, 2017, 05:02:19 PM »
*Originally Posted by jonny1978 [+]
Jonny sounds like yours could be another issue but enakki sounds like a flat battery, keep us posted on what happens at dealers good luck.
Offline jonny1978
  • Gender: Male
« Reply #14 on: August 12, 2017, 05:09:27 PM »
Fingers crossed mines is cured. Just wish I knew what had cause it. Really had massive regrets about buying a Triumph. Then I picked it up and drove it home and all they regrets disappeared  :007:
  • Gender: Male
« Reply #15 on: August 12, 2017, 07:02:41 PM »
Did you trailer it home then  :027:
Offline jonny1978
  • Gender: Male
« Reply #16 on: August 12, 2017, 08:46:46 PM »
Offline enakki
  • Gender: Male
  • Country: Slovakia
« Reply #17 on: August 18, 2017, 10:24:37 AM »
well I'm just going to pick it up from the dealer. they have kept it for two days. reflashed the ecu map which seems helped. rs is starting at first try.
the frozen clock issue hasnt been solved despite they replaced the display firmware so they are waiting for the reply from triumph what to do. seems some serious bug or hardware problem. I have noticed one more bug there. once my fuel is on warning level the remaining distance is showing as mile distance despite i have set km as the unit. but this shows the warning statis only.
Offline enakki
  • Gender: Male
  • Country: Slovakia
« Reply #18 on: September 24, 2017, 09:27:52 AM »
So here is an update. They reflashed ecu maps and also the display firmware. Dealer was told by Triumph they are aware of that problem and reflash the display firmware should solve the problem. It did not for me. the RS started at first try but it seems it was kind of a random luck or whatever. The thing is the problem was back. Strange thing happened when I went for a few days trip. It was able to start at frist try which surprised me, and the clock on dash was showing different time than before even it was frozen. It seems the clock was running for some period during the night and bike started then at first try. Weird.
The same was happening two day in row. Clock frozen, but showing different time. Started. Quite nice. Until one day when clock did not moved at all during the resting hours. And RS was starting at 5-6th try.
So it went to dealer again.
They had to go throught the reflashing procedure again (as it was step required by Triumph) and after no success they replaced the display unit.
Guess what happened. RS is starting at first try and clock is not frozen anymore.
Wird stuff but seems to be some electronic problem. I'm not happy that such a basic and common procedure like engine start is so dependent on some display unit if there is ECU for such things..
I hope I won't be posting more (negative) updates regarding this issue.
Online Mart62
  • Gender: Male
  • Bike: Matt Silver 765 RS
  • City / Town: WITHAM
« Reply #19 on: September 24, 2017, 10:04:47 AM »
The clocks /display is part of the imobaliser.
Back to the dealer.
We had a Nissan do a similar thing.
Your need a good Tec who is ok to read the Triumph equivalent of  missing frame data.
That way you should be able to see what signals incorrect.
What's the imobaliser light doing?
2>4
