Author Topic: Power commander or dyno session?  (Read 592 times)
Offline Dreadnought
  • Bike: Gen 1 Street Triple
on: November 18, 2019, 08:15:21 PM
After upgrading the 2009 ST with, k & n filter, decat and open silencers I'm keen to get the fueling set up, question is, do I go Power Commder or get a map on the ECU, say the Triumph track one, or do I go for a dyno session?
Re: Power commander or dyno session?
Reply #1 on: November 18, 2019, 08:23:03 PM
If you buy a Lonelec OBD II cable and Tune ECU, you can flash the TOR map for you VIN yourself. Mine felt better when I did this for my 2009 R after fitting SC Project cans.
Failing that you might as well take it to a tuner and get them to build a custom map for your bike and flash the stock ECU.
Last Edit: November 18, 2019, 08:40:54 PM by OuzoStreet
Offline Dreadnought
Reply #2 on: November 18, 2019, 08:25:39 PM
I was thinking TOR map, that'll be step 1 I guess, then find a 675 specialist if it doesn't feel right
