Author Topic: How to measure fork height ?  (Read 387 times)
Offline Matte Mike
  • Bike: 2014 Striple R
  • City / Town: Manchester
on: April 26, 2020, 02:55:58 PM
Hi all,
Just a quick one. The workshop manual for the 2013 Street Triple advises the following when it comes to setting fork height:
However I have found that the lower face of the upper triple to not be perpendicular to the forks. Thus it is possible to achieve a 28mm in different ways.
Does anyone know for sure where to measure from on the underside of the upper triple ?
To expand on this I have made this crude drawing.
Note 28mm measured towards the front of the fork goes from the lower face of the upper triple to the top lip of the fork.
However the same 28mm measurement taken on the outer most point of the triple reaches above the fork.
Last Edit: April 26, 2020, 03:05:25 PM by Matte Mike
Offline Stevie
  • Bike: Street triple r
  • City / Town: Newcastle
Re: How to measure fork height ?
Reply #1 on: April 26, 2020, 09:25:52 PM
Hi sorry I can't answer your question, but that's a pretty good drawing.
Offline Matte Mike
Reply #2 on: April 30, 2020, 10:58:19 AM
*Originally Posted by Stevie [+]
To clarify, im only responsible for the red notation. :D
Reply #3 on: April 30, 2020, 11:13:47 AM
The consensus seems to be around 4mm of the fork leg (not inc. the cap) above the clamp is standard from what I've read on various forums. Mine are 4.5mm and the turn in is fine which agrees, so start there.
Offline youngy
Reply #4 on: May 02, 2020, 02:55:48 PM
your datum is wrong.
this is the wording from Triumph:
"Position the forks within the yokes so that the lip of the outer tube, not the top cap,
is 28 mm above the flat/machined surface on the underside of the upper yoke."
the flat/machined surface is actually the bottom face of the yoke where the handlebar clamp mounting bolt goes through.
the manual has a drawing from a different angle showing this. Unfortunately I'm not savvy enough to add it here. you will have to look at the bottom of the yoke to see.
Last Edit: May 02, 2020, 02:58:26 PM by youngy
Offline Matte Mike
Reply #5 on: May 21, 2020, 08:12:42 AM
Thanks for your input guys. I had another look and found the machined flat tucked right under the triple clamp. It is on the very inside of the fork leg so a little tricky to measure, but a little more accessible if turning the bars to one side.
Reply #6 on: May 21, 2020, 10:29:18 AM
I wouldn't lose too much sleep on getting it exact, bearing in mind tyre wear and pressure could mean +/- 5mm difference in actual front height.
