Author Topic: Sprocket upgrade for 2010 STR  (Read 1834 times)
Re: Sprocket upgrade for 2010 STR
Reply #10 on: July 12, 2020, 07:16:53 PM
*Originally Posted by Eirik [+]
I'm sure I will  :028:
It will probably also be a good opportunity to install heated grips while doing the throttle mod.
By the way, I modified the air intake this evening. I do not have high expectations, but I thought it wouldn't hurt :002:
Eirik - unfortunately the throttle tube mod is the part from the Speed Triple and is the tube and the grip together. Not sure how feasible it is to get the grip off to fit the heated grip
Reply #11 on: July 12, 2020, 07:55:20 PM
*Originally Posted by RedBikeAgain3 [+]
Shirley you can get a Speed Triple heated grip  :027:
Reply #12 on: July 12, 2020, 08:10:50 PM
*Originally Posted by Tomspurs [+]
Donít call me Shirley, but good point I had not thought of it that way 🤦‍♂️. Probably are Speed Triple oem heated grips 👍
Offline Eirik
  • Bike: 2010 Street Triple R
  • Country: no
Reply #13 on: July 13, 2020, 10:24:29 AM
*Originally Posted by Mpact [+]
Personally I think this intake guard removal is a better mod than replacing the mufflers. The noise it makes when accelerating is fantastic.
I have to agree with you. It made a difference :028:
I made a new intake guard after getting inspired by some post here on the forum:
By the way, I see you have a facelifted 2011? Have you swapped to a newer generation headlights?  I would like to do this on mine.
-Eirik
Offline Eirik
  • Country: no
Reply #14 on: July 13, 2020, 10:31:15 AM
I suspected that after doing some research. But thank you for your input!  :028:
-Eirik
Offline Eirik
  • Country: no
Reply #15 on: July 13, 2020, 10:33:38 AM
Thanks for the advice  :028:
-Eirik
Offline Mpact
  • Bike: 2011 STR facelifted
  • Country: ie
Reply #16 on: July 13, 2020, 11:44:48 AM
My bike is the one with the 5 pointed headlights. I'm considering fitting the older round headlights though as both my lenses are cracked and replacements are very expensive.
On the throttle tube mod, I didn't actually fit a Speed Triple throttle tube. I got a piece of plastic tube, inside diameter 32mm, outside 35.5mm. cut it into a "C" shape, around 5mm wide and fitted it onto the original throttle tube.
