Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
Please
login
or
register
Street Triple
Main Street Triple Board
Suspension Set-up and Mods
Rear Tyre rubbing on the shock linkage
17 Jan 21, 22:54 PM
« previous
next »
Pages: [
1
2
Go Down
Author
Topic: Rear Tyre rubbing on the shock linkage (Read 1175 times)
AndyFaeLarky
Street Triple Member
Topic Author
Bike: Street Triple RS
City / Town: Larkhall
Country:
on:
September 20, 2020, 02:42:32 PM
Just noticed an issue with my Street Triple RS 2020.
Looks like the rear wheel is rubbing in the rear shock linkage, nothing has changed recently - what the feck is causing this???
Andy
Logged
Green_Ninja
Street Triple Master
Bike: Street RS/Street R
City / Town: Sale
Country:
Re: Rear Tyre rubbing on the shock linkage
Reply #1 on:
September 20, 2020, 02:47:56 PM
Just popped out to the garage to have a look at mine and I can't see how it would be possible for the linkage to contact the tyre. at rest there is at least 2" clearance from the linkage to the tyre and as the suspension comoresses the linkage moves away from and not towards the tyre.
I think the tyre marking has another casue but no idea what it is.
First thing to do is have a good look at he suspension linkages as if something is rubbing it should be fairly obvious as it will me marked/rubbed.
Logged
AndyFaeLarky
Topic Author
Country:
Reply #2 on:
September 20, 2020, 02:50:33 PM
Thanks,
Yeah, I did have a look at the linkage that is closest to the tyre and its shinny and look similar to the rubbing marks.
The chain does need adjusted - dont see what that has to do with it tho..
Andy
Logged
AndyFaeLarky
Topic Author
Country:
Reply #3 on:
September 20, 2020, 03:26:37 PM
Ok,
Had had the wife sitting on it and bouncing up n down (which was fun to see) and it looks like there is no chance of the linkage hitting the tyre.
It's bloody strange - need new tyres anyway, maybe just comming to the end of their life and wheel spinning easier.
Oh and adjusted the chain - looks like is wasnt right from the factory, the markings were different from each other.
I have adusted it to be even on both sides now.
Andy
Logged
Tomspurs
Street Triple God
09 ST, CRF230F, DT175MX, DT175C, PE175Z, IT175J
Bike: 09 Hinkley ST
City / Town: Wallington
Country:
Reply #4 on:
September 20, 2020, 07:22:55 PM
Originally Posted by
AndyFaeLarky
Not being adjusted true, would lead to increased tire wear and would cause slight "dragging" .... a tyre expert on here may know
Logged
tim.8061
Street Triple God
Bike: Street Triple 09
City / Town: Gloucester
Country:
Reply #5 on:
September 20, 2020, 07:24:33 PM
The swingarm marks are not necessarily accurate, you need to use an alignment tool to do it properly. Easy enough to make something DIY if you google it.
Logged
Tomspurs
Street Triple God
Bike: 09 Hinkley ST
Country:
Reply #6 on:
September 20, 2020, 07:26:28 PM
I did my chain about an hour or so ago. I used a bore gauge / internal gauge thingy, to get both sides even then used the bolts to adjust...works a treat
This one (bore gauge "c" fitted between the swing arm inner casting and the adjuster body. Set them up the same using the adjuster bolts...check the chain tightness and adjust evenly / by the same amount either side from there on in
https://www.amazon.co.uk/HFS-Precision-Telescoping-Gage-Set/dp/B00R5E5PI6/ref=sr_1_13?crid=1ILDLZAEXL3IF&dchild=1&keywords=bore+gauge&qid=1600626407&sprefix=bore+gauge%2Caps%2C145&sr=8-13
Last Edit: September 20, 2020, 07:29:15 PM by Tomspurs
Logged
Rob R
Street Triple Pro
Bike: Street Triple
City / Town: Walsall
Country:
Reply #7 on:
September 20, 2020, 08:46:44 PM
Looks similar to the my tyre after some gravel got caught in the hugger. I heard it before I saw the damage though.
Rob
Logged
RedBikeAgain3
Bike: 2015 ST ABS noneR
City / Town: Lincoln
Country:
Reply #8 on:
September 20, 2020, 09:17:58 PM
I was thinking hugger too. Slight loose or flexing, or fitted very close to the tyre. Does the tyre expand slightly with centripetal force when the wheel is spinning at speed. Tip of the hugger on my 2015 is sort of two points.
Logged
AndyFaeLarky
Topic Author
Country:
Reply #9 on:
September 21, 2020, 09:40:46 AM
There is nothing fouling the tyre.
Convinced its the tyre, its done 3500 miles so think it is just breaking up - have order a new set of boots for the bike anyway.
Dunlop Roadsmart 3's.
Andy
Logged
Pages: [
1
2
Go Up
« previous
next »
Mk1/2 rear shock flux linkage plates
For Sale Board - Motorcycle Items
gvy
Today
at 12:25:24 PM
Engine Blown
General Maintenance, Servicing, and Mechanical
Tomspurs
Today
at 11:07:49 AM
Mk1/2 seat cowl
Deefer
Today
at 10:03:48 AM
Modified R1 shock- to fit mk1/2
Deefer
Today
at 09:52:50 AM
Newbie
New Members
adiepage
Today
at 09:48:14 AM
New Member... Old Biker
New Members
hotmetal
Yesterday
at 12:06:49 PM
Headlamp cowl differences
"Home-made" DIY Street Triple Mods
adiepage
Yesterday
at 11:10:20 AM
2020 RS deals?
Street Triple - General Discussion
2012StreetT
January 15, 2021, 04:30:56 PM
Rear tyre advice
Tyres and Wheels
sabre
January 15, 2021, 08:49:48 AM
New here backto bikes
New Members
gvy
January 14, 2021, 10:09:53 PM
