Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 765 switched power for a GPS?  (Read 1044 times)
Re: 765 switched power for a GPS?
« Reply #10 on: July 19, 2018, 05:39:22 AM »
*Originally Posted by vayduh [+]
https://www.amazon.co.uk/Cliff-Top-Motorcycle-Magnetic-Power-Charger/dp/B00QTA1G7Q
Something like this may be of interest to those that want usb power without any battery drain.
Personally I just connect mine up using ctek connectors when I want mine on and leave it disconnected at all other times.
Hi vayduh, link doesn't seem to work. Thanks for the post, it's a topic I'm interested in.
David
Offline vayduh
  • Bike: STR 2013>
« Reply #11 on: July 19, 2018, 09:20:54 AM »
Just go onto Amazon and search for
Cliff Top usb battery drain
Offline Belifant
  • Country: Switzerland
« Reply #12 on: July 20, 2018, 09:00:35 AM »
if you don't have heated grips, I would use the heated grips port under the tank for switched power (even protected by its own fuse in the fuse box).
https://www.street-triple.co.uk/index.php/topic,31226.0.html
Offline Tripleboo
  • Bike: Street triple 765 R
  • City / Town: Stockholm
  • Country: Sweden
« Reply #13 on: November 08, 2018, 07:24:15 PM »
The heated grips plug is no good since it's switched not only by ignition but in two,three steps. Follow the connection to the underseat USB connector it's switched over the ignition and is 12 v. Just tap into that wire!
Cheers!
Magnus
Here I am!
