Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2012 engine swap uncertainty  (Read 1021 times)
Offline ollies41
  • Bike: Street triple/SV650
« on: October 31, 2018, 03:38:56 PM »
I have a 2012 675 (model with new headlight shape) and seen an engine to fit 2007 to 2012. I'm wondering if there is a risk the engine isn't going to fit my model even though is says it would fit 2012? Did the engine change at all in that year?
Hopeful... :187:
Insanity, a perfectly rational adjustment to an insane world.
R.D.Laing
Re: 2012 engine swap uncertainty
« Reply #1 on: October 31, 2018, 05:06:53 PM »
*Originally Posted by ollies41 [+]
Hopeful... :187:
I don't know for certain but I've always thought that the changes to the "Dame Edna" were largely cosmetic/styling, suspension and brakes but didn't have any fundamental changes to engine & chassis, etc.   As it had twin underseat exhausts I think it's likely that main and sub frames were the same so the engine should fit.  I've just seen one ride review that states that the " ... engine is unchanged ..."   Not sure about gearing, though, but that's not going to prevent installation.   You could always call your local main dealer or even phone Triumph  themselves?
Offline Green_Ninja
« Reply #2 on: October 31, 2018, 05:19:13 PM »
I am sure that all Underseat exhaust Striples (whether round or Dame Edna headlights) have the same engine. The change came with the 2013 Model year that introduced the low level exhaust, this has a lower first gear.
Offline Admin
  • Administrator
« Reply #3 on: October 31, 2018, 06:13:56 PM »
If available the VIN from the donor bike would confirm it but I'm guessing thats not known (or is it) ??
« Reply #4 on: October 31, 2018, 06:38:33 PM »
The first Dame Edna version was ironically just a face lift. (I'd want a refund TBH.)
Offline ollies41
« Reply #5 on: October 31, 2018, 07:16:54 PM »
I don't have the VIN from the original bike. The more research I'm doing the more I'm seeing the changes were more cosmetic rather than in the actual engine.....just want to make absolutely sure, could do with an article that says for definite that no changes were made till the 2013 model. Must be one somewhere...... makes sense what you're all saying definitely
R.D.Laing
Online kam
  • The more you learn, the less you know. . .
  • Bike: STR 2010/GSXR 1000
  • City / Town: Surrey
« Reply #6 on: October 31, 2018, 07:57:37 PM »
Only thing I'd look out for would be the exhaust header ports. I think earlier engines had round exhaust ports and later engines had oval ports so make sure you check this with your engine otherwise you might need a set of headers too if they don't match with yours.
« Reply #7 on: October 31, 2018, 08:39:22 PM »
I believe the only changes were:
  • Engine case.....the 2011 to 2012 ones had the Triumph logo on and were a slightly different shape but in essence the same
  • The Sept 2009 models had a harness with the quickshifter plug0
Other than that I believe it all the same so it will fit IMO  :031:
Offline bryspky
  • Bike: 2011 STR
  • City / Town: durham
  • Country: uk
« Reply #8 on: November 01, 2018, 10:12:07 AM »
Kam and Tomspurs are correct engine will fit frame
Offline ollies41
« Reply #9 on: November 01, 2018, 05:20:46 PM »
Thanks everyone  :031:
R.D.Laing
