Author Topic: wont start  (Read 1746 times)
Offline bryspky
  • Bike: 2011 STR
  • City / Town: durham
wont start
on: November 30, 2018, 04:19:12 PM
went try start street triple 2014 today have ride wont start
turns over very fast fuel pump make noise when turn ignition on just wont fire up
fresh petrol
heard stators going wrong could this be  rotar pick up stoping it from sparkig
not checked plugs yet see spark
any advise thanks
Offline Tripletrev
  • Bike: Street triple 765r
  • City / Town: LONDON
Re: wont start
Reply #1 on: November 30, 2018, 06:03:16 PM
Hi , my 675 15 plate did the same it turned out to be the alarm. Has your fitted with one.  Trev
Offline bryspky
  • Bike: 2011 STR
Re: wont start
Reply #2 on: November 30, 2018, 06:29:20 PM
*Originally Posted by Tripletrev [+]
No Alarm fitted Trev
  • City / Town: Gloucester
Re: wont start
Reply #3 on: November 30, 2018, 07:03:03 PM
Yes could be the pick up by the alternator aka Crank Position Sensor CPS.
Lots of threads on here and triumph675.net including a few tests.
Offline bryspky
  • Bike: 2011 STR
Re: wont start
Reply #4 on: November 30, 2018, 07:11:53 PM
*Originally Posted by tim.8061 [+]
Crank Position Sensor that thought come to me straight away tim
bike was running excellent week ago
Re: wont start
Reply #5 on: November 30, 2018, 07:46:22 PM
Meter it, should be around 200 ohms. If it's short or high resistance then it's effed. However if it reads OK it still might be toast. They are wired in with the stator harness so its one expensive bit from Trihmph, You can get them separate from the stator but not from Triumph, and you'll need to cut then resolder wires.
Re: wont start
Reply #6 on: November 30, 2018, 08:03:38 PM
Here's more https://www.street-triple.co.uk/index.php/topic,31311.msg352345.html#msg352345
BTW If you have the tank up and airbox off to check for a spark, the tip over sensor can be disconnected and it will be as if it's not tipped over . If you have it connected it has to be horizontal otherwise it stops it firing.
Offline bryspky
  • Bike: 2011 STR
Re: wont start
Reply #7 on: November 30, 2018, 10:00:47 PM
[/quote
the tip over sensor under seat behind battery  2014
think you mean 2009-2012
Offline bryspky
  • Bike: 2011 STR
Re: wont start
Reply #8 on: November 30, 2018, 10:09:37 PM
Never had this problem so do they just stop working when fancy ride out
Re: wont start
Reply #9 on: December 01, 2018, 09:04:11 AM
The tip over sensor on my 09 is on the airbox, so if you take airbox off and lay it over the side to get a plug out it wont spark unless you disconnect the sensor.
