Author Topic: stators and reg/recs  (Read 598 times)
Offline trickymicky
  • Bike: street triple 675
on: November 10, 2019, 11:49:11 PM
just bought my 08 triple 2 weeks ago and am a new member on this site.i have been looking at postings on the site and there seems to be loads of problems with stators and reg/recs. is this a major problem with these bikes,can i expect to have issues in the future
Online Tomspurs
Re: stators and reg/recs
Reply #1 on: November 10, 2019, 11:58:01 PM
All you need to do is check that your 08 has had its Reg -Rec has been changed by a Triumph dealer on the recall a number of years ago. You can check this on line I think. If not, get it booked in at a dealer of your choice for a free exchange  :028:
Reply #2 on: November 11, 2019, 12:09:28 AM
I have 2 mates with 08s and no problems but there are obviously some out there.
My 3 bits of advice.
Keep oil level correct as it cools the stator
Buy a charge led available on ebay
Crimp the wires from stator.  Theres a plug under the tank that if it gets corroded will melt and cause issues.   Simply hardwired it will be out of the equation.  Easy to reterminate if replaced.   Dont use preinsulated terminals though.  Bare folded crimp and heatshrink.
Offline EllyV6
  • Bike: Street Triple 2011
  • City / Town: Lancs
Reply #3 on: November 11, 2019, 01:19:04 PM
Safety recall info here...had to check mine when I got it too!
https://www.triumphmotorcycles.com/safety-recall-search
Reply #4 on: November 11, 2019, 02:47:08 PM
Even if it has the new reg/rect get a small digital voltmeter on it and save yourself ever getting stuck with battery problems.
Reply #5 on: November 11, 2019, 06:30:28 PM
The charging led can be mounted on the dashboard and will flash if it stops charging.  Search on Evilbay.
Online Tomspurs
Reply #6 on: November 13, 2019, 10:03:22 PM
Go to Lidl and get yourself that bluetooth battery checker...does charging and starting too.....well worth the money
Reply #7 on: November 14, 2019, 08:26:11 AM
If my battery is low my tracker sends me a text message. I ignored it the first time it happened. I won't ignore it ever again. It tells the truth  :003:
Reply #8 on: November 14, 2019, 05:09:41 PM
But then you have to remove the seat to plug it in everytime you want to check, and then remove it after. Seems a bit overkill when you can have a small digital voltmeter fitted permanently for a couple of quid.
